Longitudinal frame twisting and different kind of holes in transverse frames
Discussion in 'Boat Design' started by Joonatan, Jan 31, 2025.
  1. gonzo
    Likes: 2,389, Points: 123, Legacy Rep: 2031
    I understand what you are saying now.
  2. Waterwitch
    Likes: 51, Points: 28, Legacy Rep: 20
    Waterwitch Senior Member
    My rule of thumb for mouse holes is reality based having cut them in steel plates, I beam and angle bar ends building ship structure. We have no idea of the scale of
    the OP's hypothetical design to say how big of a mouse hole.
  3. Ad Hoc
    Likes: 2,009, Points: 113, Legacy Rep: 2488
    As already noted, the mouse at the base, is to allow the welder to perform a return around the web. This prevents cracking, if left as a stop/start at the end of the mouse hole.
    As an extreme example, not performing returns, can lead to cracking in other locations too, like here:
    In general mouse holes/cutouts are not to be greater than 50% of the web depth, it is passing through.
    As for shapes and guidelines, there are many, such as:
    DNV's
    LRs
    And you also need to be careful when creating the shape of the mouse hole and its objective, since this relates to cracking from fatigue.
    Such as:
    It is a very very deep rabbit hole, if you wish to go down this route.
    Viz:-
    gonzo likes this.
  4. Joonatan
    Likes: 1, Points: 3
    Joonatan Junior Member
    Thank you very much for this more detailed answer!
