Hey guys,
I have a few questions to you about designing boats (steel or aluminium BUT especially in aluminium)
In the first picture you can see a simplified example of bottom plate and longitudinal frame. I have couple questions regarding that:
1. Should the aim be that the longitudinal frame is always perpendicular to the bottom plate (yes I know it helps with scantling calculations but what is too much angle in general when boats are designed)?
2. Is it bad thing, if the longitudinal frame is twisting a lot (as you can see in the picture) towards the front section of the boat? If you need to force the flat plate to it's place then it is bad but otherwise it is okey? is this correct?
3. If twisting is bad, should the longitudinal frame be cut in few shorter pieces and then assembled so that it would not always be perpendicular to the bottom plate, but at least it would not be twisting that much.
My second questions is regarding the holes in transverse frames.
as you can see in the second picture, there are 3 different kind of holes. I have seen all of these used in boat building (when searching the internet). But is there a place for all of these different cuts?
4. Why I should not use the middle one always if building a boat?
5. If the left cut in the picture is helping to relief stresses, should it be used always?
6. Which one of these holes should be used for the bottom plate of the boat?
7. Could you give some practical examples when to use each of these cuts, or if some of them should be avoided always.
I would really appreciate if some of you have wisdom for these questions. Especially if you could give some good practises/rules ("rule of thumbs") to follow in general.
