livewell repair
Discussion in 'Materials' started by madfish, Sep 13, 2014.
  1. madfish
    madfish Junior Member
    I am repairing a livewell that has cracks around the bottom. It is a fiberglass well and assume gelcoated. After repairing with fiberglass should I coat with gelcoat or is there a special paint? I would like to make it light blue also.
    You could gelcoat again. Make sure that you get waxed so the surface cures. Another easier way is epoxy paint.
  3. PAR
    Since it's a live well, I'd not use epoxy paint as the sealant, just as a top coat to offer some color. This will only be necessary if you don't gel coat. The gel coat will seal the surface, but a good color match will be difficult. Inside a well, I'm not sure this is as import. If it is then consider the epoxy paint, but only as a uniform coloring, not as a sealant. If it was me, I'd just gel coat it and call it a day, regardless of the color match.
