messabout
Senior Member
- Joined
- Jan 19, 2006
- Messages
- 3,492
- Reaction score
- 609
- Location
- Lakeland Fl USA
The last picture shows the flotation bags lashed to the floor. They are also located far aft. The bags will no doubt displace enough water to float the entire boat. When placed aft as in the picture, the back of the boat will remain afloat but water will run toward the bow of the boat, potentially sinking the bow. The flotation bags need to be centrally located, but in a boat of that size the bags will not allow the skipper to move from side to side enough to counteract heel. The skipper might possibly be able to sit atop the bags as needed.
My flattie/skiff/ sharpie is 4.8 meters x 1.3 meters, it's flat bottom is one meter wide. It has a 5.5 square meter sprit boomed sail and an alternative 7.5 meter square lateen rig. The boat goes like a bandit with either sail. The sprit boom is my usual go to rig for its simplicity and ease of storing. Wind the sail around the free standing mast and the job is done. I have some lines wrapped around the base of the mast and the ends led aft to cleats. By pulling the correct line the mast will rotate and douse the sail entirely. Pull the other string and the sail unwinds from the mast.
I have never capsized the boat in all these 15 years. I am a light weight guy of about 72 kg and the boat has been sailed in some vicious weather with out dumping it. I do have some flotation foam blocks that are sufficient to keep the boat afloat if capsized. The foam is placed at the approximate center of gravity of the boat.
I am being a hard head and continue to insist that a simple sail with light spars are the best option for old guys like me (and you). The sprit boom keeps that weight down low where it makes the aloft weight modest. Every centigram aloft matters because of leverage which magnifies inertial forces.
My book; The Encyclopedia of Wood, does not list Paulownia or KiriKiri. The closest one I could find was Obeche, which is light, fairly strong, and has color similar to that of your boat. Perhaps Paulownia has a different name when translated.
Best wishes to you from another old sailor in Florida, Dieter51
