Capn Bogbrush
Junior Member
- Joined
- Oct 2, 2019
- Messages
- Reaction score
- Location
- Europe
I've had a look around the forum and there are a number of older threads that look like they might be useful but I guess those were conversations that ran their course at the time and, bearing in mind the notice which talks about accidental bumping, I thought it probably best to start a new thread.
So here goes.
I've heard a lot about lithium batteries - the advantages being especially how they will tolerate being stored part charged (SoC) and their ability to withstand much greater depth of discharge (DoD). I also heard that they can stand many more charge/discharge cycles; the disadvantages I've heard about include cost, instability and they won't take charge below 0°C.
This last one was the killer as far as I was concerned but then I heard of a new chemistry - lithium titanate (LTO) which is stable and takes charge down to -20°C and below. Unfortunately there doesn't seem to be very much info about the practicalities of using these cells so I'm hoping someone has knowledge they can share. Of course, I'd love to hear all the reasons why I shouldn't even consider using such a new technology but be warned, obstinacy runs in the family...
My plan is to build a 12 volt battery to replace my existing 460Ah bank of 4 SLA batteries that live in the engine hole and power a 3kVA inverter. Don't ask me why the boat builder went for 12V to power such a monster inverter - to run it at its rated power means supplying 300A which is a big ask for even proper leisure batteries and the ones I have are well past their prime. And SLAs take time to recharge - even if you've drawn 75A out you can't necessarily put that much back (and, indeed, I can't - the alternator is rated at 150A which means its theoretical maximum output would only be 37.5A per battery). But LTO cells will take charge at 10C which for a 40Ah cell is 400A.
The other problem I foresee is that LTO cells will take charge at 10C which means they'll try to suck as much charge as they can from the alternator even when it's not running at its rated speed which is likely to lead to overheating and ultimately destroy it. Frankly, this is my greatest concern. Should I buy a new alternator that's designed for charging lithium cells? Does anyone know where I can get one?
So here goes.
