Gaff Cat pt2
Discussion in 'Boat Design' started by Manie B, May 31, 2008.
  1. Manie B
    Likes: 123, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
    This has taken quite a bit of time
    however it was certainly worth the huge effort
    most definately two escape hatches
    thanks guys - they drew out fine (boat upside down)
    i am busy tidying up the cad
    will start posting clear drawings soon
  2. Manie B
    hi guys will you please see if you can open the following
    the side view should open in Rhino and Turbocad
    the Delftship hopefully should also open in Delftship
    i am hoping to get a clearer picture out there for general comment as i go along
    these are the things i am "tweaking" at the moment to ensure that everything "matches" with the "parameters"
    still a lot of work to go
    i am finalising the architectural design at present = galley up - and fresh water below for ballast
  3. Manie B
    this is it
  4. Manie B
    delftship opens easy
    dxf i save to Rhino
    open Rhino and open dxf CAD Gaffcat side
    make sense???
