Lion 800 new plywood yacht
Discussion in 'Boat Design' started by Unik, Jul 22, 2016.
  1. Unik
    Likes: 47, Points: 38, Legacy Rep: 24
    Unik Senior Member
    September was quite fruitful, a longitudinal set of deck and felling was installed, and the outer plating was started.
    More info
    Niclas Vestman likes this.
  2. rwatson
    rwatson Senior Member
    Exciting times.
  3. Unik
    Unik Senior Member
    This week, the assembly of the deck, deckhouse and cockpit deck in the cockpit is complete, a large bulkheads are installed behind the aft bulkhead to store equipment and things.
    More info
  4. Unik
    Unik Senior Member
    News from the construction yachts Lion 870
    After the completion of the deck assembly, all joints between the parts were sealed with epoxy resin mixed with wood dust, after polymerization a complete grinding of the deck and pasting with two layers of fiberglass on an epoxy binder will be carried out.
    More info
  5. Unik
    Unik Senior Member
    Before the deck was covered with fiberglass, all the cutouts for the installation of manholes and portholes were cut.
    More info
  6. Unik
    Unik Senior Member
    The joints of all the parts of the deck were plastered, in the places of installation of the hatch coamings, fillets were made, the deck was polished and prepared for gluing with fiberglass.
    more info
  7. rwatson
    Seems to be progressing nicely.
    When you get a chance, I would be interested to know what paint system you are going to use, and how much it costs over there.
  8. Unik
    Unik Senior Member
    For plastering and painting this boat, we use the AWLGRIP system.
  9. Unik
    Unik Senior Member
  10. Unik
    Unik Senior Member
    November, the air temperature does not allow you to work outside, so the yacht construction work is moved inside the yacht, the use of an electric heater allows you to get a comfortable temperature in the yacht for work. Work began on the interior decoration of the yacht, we published many photos of the yacht, you can now look at the yacht Lion 870 from the inside.
    http://unikyachts.com/en/lion-800-construction-part-3/8/
      File size:
      40.6 KB
    pafurijaz likes this.
  11. Unik
    Unik Senior Member
    The construction of the yacht has been resumed, this week the deck of the yacht is peeled from the outside with two layers of fiberglass based on epoxy resin, for pasting
    A glass cloth with a weight of about 300 g / m2 is used
    More info
    rwatson and pafurijaz like this.
  12. pafurijaz
    Likes: 70, Points: 38, Legacy Rep: 18
    pafurijaz Senior Member
    Beautiful this threads, thanks for sharing the various stages very useful ..
  13. Unik
    Unik Senior Member
    A week passed, more news from the construction of Lion 870, the deck is covered with a second layer of plastic, now putty and coloring.
    more info
  14. Unik
    Unik Senior Member
    For a long time I did not write about the construction of the Lion 870, there was no free minute, the construction is in full swing, the building is completely covered and plastered, preparations are underway for painting the deck and installing hatches and portholes.
    more info
    rwatson likes this.
  15. Unik
    Unik Senior Member
    Lion 870 Construction continues, details will be available soon.
    Niclas Vestman and rwatson like this.
