lines plan
Discussion in 'Software' started by jollyricard, Jul 4, 2010.
  1. jollyricard
    jollyricard Junior Member
    Can I change the lines plan in autocad? I want to lengthen or widen the hull, what is the best procedure ?
  2. RAraujo
    Likes: 22, Points: 18, Legacy Rep: 114
    RAraujo Senior Member - Naval Architect
    I don't know exactly what you intend to do but have you can convert to blocks and then modify the X, Y Z scales. Then you can EXPLODE the blocks to have the individual entities.
  3. zeroname
    Likes: 5, Points: 0, Legacy Rep: 90
    zeroname Naval Architect
    best is, make a 3D model from your lines and then lengthen or widen the model using rhino or maxsurf or other softswares and recreate Lines .
    If u dont want to create 3D model it will be hard to lengthen or widen because you have to work through control points,and there may be a lot of control points you need to move to produce a fair lines again ,,
    ty
  4. apex1
    apex1 Guest
    This may sound dumb (or discouraging), but the best way is to know beforehand which consequence that has. Then decide about the way to draw it.
    Regards
    Richard
  5. jollyricard
    Thanks, Rhino is the best solution but I do not know the commands to modify the lines plan in autocad, how do I convert the block and change xyz?
  6. RAraujo
    Follow the following steps - capitals for command names - (the results will depend on how your hull is defined):
    - if your lines drawing is defined as 3D objects
    BLOCK
    name the block with a coonvenient name
    select all objects in the drawing
    select 0,0,0 as your base point
    click OK
    INSERT
    put the block name
    select 0,0,0 as your insertion point
    put the desired xyz scales
    click OK
    EXPLODE
    select the inserted block
    you should have the lines modified now
    - if your geometry is defined by horizontal (waterlines), vertical (stations) and longitudinal (buttocks and profile) sections you shall apply the previous process to each projection.
    Hope I was able to explain...
    Regards.
    Rodrigo
  7. jollyricard
    thanks, I will try to follow the procedure
