Guys I heard my first rumble of the season a few days ago. My boat is a new homebuilt catamaran. The bridge deck is open with an aluminum frame to support an awning, other than that not much metal, except the rudder posts and connecting tubes, and the compression tubes forward. The two shrouds and headstay terminate at composite chainplates, about five feet above the water.
I think I want to run an aluminum cable straight down through the deck at the base of the mast. My thinking is to use heavy aluminum wire with aluminum fasteners connecting it to the aluminum mast step. It seems to me that aluminum would be better, since copper and al don't get along. This cable would not actually go into the drink, just a few inches above, so I could leave it there without worrying about it. I have one of these fuzzy things at the masthead, but no grounding cable running down the stick.
At the shrouds, what about clamping a ss wire to the shroud ( I really don't like the idea of clamping anything the the shrouds- but what else can you do?) and chucking it overboard if (when) I am underway in a thunderstorm.
The other stuff is all aluminum except the anchor and chain. (don't know what to do with that)
but, anyway, the reading I have done everybody always specs heavy copper wire, which to me makes no sense if you are bonding the thing to aluminum. What do you think?
ps it seems that the aluminum frame for the awning would act as a kind of faraday cage-- I could connect some aluminum wires to the thru bolts where the legs fasten to the deck, and let them hang down in the same fashion as the main grounding wire at the mast. I know all this wire dangling down below the bridge deck would look pretty weird, maybe I could fasten some tethers to the ends and pick them up so they would be up against the bottom of the bridge deck, and let them down in a storm. maybe.
has anybody else done it that way? I am scared of lightning.
