Lightest and Strongest Hull... What Materials and How??
Discussion in 'Fiberglass and Composite Boat Building' started by kyboatbuilder, Jan 12, 2008.
  1. JohnMc
    Likes: 1, Points: 0, Legacy Rep: 7
    JohnMc Junior Member
    A thin OK1088 marine ply with epoxy and a couple layers of fabric has got to be one of toughest laminate schedules.
  2. cahudson42
    cahudson42 Junior Member
    Kyboatbuilder,
    This is going to sound retrograde, but for a 21' Bass Boat why not just use 5086 0.125 Al?
    Weld it up as a giant 'box beam'(s) and you will have one heck of a strong boat.
    I'm looking at an 18' in Delftship and the Al 5086 material weight is maybe 300 lb. By the time you add yourself, the motor, fuel, etc. - whats really going to be the performance difference between a 300 lb AL Hull and some exotic Hull that maybe weighs what - 150 lb?
    What am I missing here?
    Chris
  3. Jimbo1490
    Likes: 41, Points: 28, Legacy Rep: 527
    Jimbo1490 Senior Member
    Aluminum is stiffer than E-glass, even if the E-glass is layed up as skins on a foam core with epoxy and vac bagged. That's why he'd have to go with at least S-glass or carbon skin sandwichto one-up a good aluminum boat. But stiffness (as in bending, panel stiffness) is driven by the thickness of the panel, so you'd still have to address that with an aluminum design. The box beam is one way of doing that; sandwich construction works with aluminum skins, too.
  4. longliner45
    Likes: 73, Points: 0, Legacy Rep: 505
    longliner45 Senior Member
    wood,,,,,longliner
  5. FAST FRED
    FAST FRED Senior Member
    Just be sure it does not have to go back to a factory & autoclave to repair minor damage.
    FF
  6. tinhorn
    Likes: 20, Points: 18, Legacy Rep: 310
    tinhorn Senior Member
    Years ago I played with some 3D fabrics skinned with a Kevlar/graphite weave and one-ounce mat, with VE resin filled with microspheres. Unbelieveably light and rigid. (Not on boats, though - prototype electric car bodies.)
    I can't even remember the name of the fabric, but I understand it's no longer available.
    I remembered! Parabeam. www.parabeam.com
  7. eponodyne
    Likes: 13, Points: 0, Legacy Rep: 171
    eponodyne Senior Member
    Wood.
    W3rd.
  8. petereng
    Likes: 22, Points: 28, Legacy Rep: 252
    petereng Senior Member
    Probably the lighest and strongest hull would be a kevlar/thermoplastic laminate. Twintex sell glass/polypropylene material and its toughness is hugh. The process would go as follows. Layup dry kevlar, interleave with perforated PET. PEEK or Nylon film. Place vacuum bag over it, put in oven under vacuum and let the plastic melt through the laminate.
    This can be done with glass as well but kevlar is less dense and stiffer.
    Eglass 2550kg/m3, E=70Gpa. Kevlar 1440kg/m3, E=110Gpa
    Petereng
  9. the1much
    Likes: 44, Points: 0, Legacy Rep: 696
    the1much hippie dreams
    last night on some discovery channel thingy,,,they showed a new stronger "high tech" carbon fiber,,i think it was C.something , something,,,,,great help aint I ;)
  10. marshmat
    marshmat Senior Member
    The thing is supposed to go 80 mph? In what sea state?
    Carbon fibre does not take kindly to impact loading; I would rule it out here because this boat is going to hit the water HARD when it chine-flops off a nice whitecap. You probably want something that will flex a bit on impact rather than cracking. To get a carbon laminate thick enough to avoid structurally damaging levels of deflection in such a scenario, you'd negate much of the weight advantage carbon has in hulls subject to more uniform loading and more gradual changes in loading.
    In pure composite methods, I would lean towards multidirectional Kevlar/S-glass hybrid fabrics set in epoxy, sandwiching Core-Cell (or Nomex, if you're adventurous).
    In metal, you could probably get similar results with a well-engineered welded aluminum structure.
    If you aren't averse to the use of wood, perhaps a strip-plank / epoxy composite method should be considered, again using Kevlar/S-glass fabrics.
    Properly engineered, you could probably see roughly comparable weight and strength using any of these methods. Note that "properly engineered" is critical in an application like this.
  11. rwatson
    rwatson Senior Member
    'Gut feeling' indicates aluminium., Especially since you are on a budget.
    Timber is great, but you are doing heavy work in rough seas, and it isnt that tough for rough use.
    Aluminium has another great advantage - no surface coating. On timber and composites, the paint/coating/gel coat finish that keeps the water out can cost a significant amount of the actual material and needs constant maintenance on a working boat.
    With aluminium, you weld, you are finished - and its very robust. For that size boat, it would be as light as you need.
  12. petereng
    Composites do not require painting or gel coating to keep the water out. Paints and gel coats are just resins with pigments in them, so thay are the same as resins with fibres in them. Resins are plastics which absorb water, just like timber but to a much lesser degree. The water absorption is a problem for polyester resins but not vinyl ester or epoxy resins. Polyester resins break down with prolonged contact of water (hydrolysis & osmosis)
    Peter S
    With composites you bond and you are finished.
  13. grob
    Likes: 5, Points: 18, Legacy Rep: 53
    grob www.windknife.com
    I have tried this and it didn't work, I don't think there is enough "resin" in the twintex to get the kevlar to bond properly. You could peel the kevlar off the laminate after it had cured. You would need to ask the Twintex people to make up a special batch especially for this purpose.
    That said I think that Twintex would be the lightest and toughest material possible, and there is probably no need to add kevlar.
    edit .. that said its not a process suitable for homebuilding.
    Gareth
  14. Pericles
    Likes: 142, Points: 63, Legacy Rep: 1307
    Location: Heights of High Wycombe, not far from River Thames
    Pericles Senior Member
  15. rwatson
    Composites DO REQUIRE COATING - for UV protection mostly and to keep water out as they all absorb water, albeit slowly
    When is the last time you saw a raw GRP boat?
