Light Weather Headsail
Discussion in 'Sailboats' started by Mr.G, Nov 14, 2015.
  1. Mr.G
    Mr.G Junior Member
    Hi all,
    I have an old wooden 12 ton 38 ft cutter - good boat - I want to improve her weatherlyness.
    Her working sails are a large main, and a 100% jib/staysail.
    She has a bowsprit.
    I need a light weather sail to put on that bowsprit with the proviso that it be set flying.
    - either a yankee / top hat style that can be the first reef
    - or a code zero/light air genoa type flown with the staysail down
    I am leaning toward the second option...
    What do you think?
  2. whitepointer23
    Don't know much about sails but i would like to see some pictures of boat if you can post them.
  3. Mr.G
    Mr.G Junior Member
    Here you go
    THis was taken in the DEntrecasteaux Channel with the old mast.
    The new mast is aa little taller.
  4. whitepointer23
    Beautiful looking boat. I am hoping to sail down to tassie when i eventually finish my boat . I am on the gippsland lakes so a trip from lakes entrance via deal and flinders islands is my plan. Will you have your boat at the next wb festival.
  5. Mr.G
    Mr.G Junior Member
    Wbf
    Yes I most probably will apply to enter the 2017 WBF.
    If you like wind and waves you are coming to the right place.
  6. whitepointer23
    We have our share this side of the paddock too. I will fly down for the festival. As to your head sail there are some very knowledgeable people on here. You shouldn't have to wait to long for some advice.
  7. gonzo
    Likes: 2,243, Points: 123, Legacy Rep: 2031
    There seems to be a forward loop on the masthead fitting for a spinnaker halyard. The problem with a halyard that close to a furling sail, is that they often get wrapped as you furl the sail. Have you considered changing the furling system to one that allows for reefing? That would give you the option of a larger headsail.
  8. waikikin
    waikikin Senior Member
    I think looking at your pic the everything looks short in the hoist... & now your mast is higher? I'd be putting money in the main to start with.
    If you're "set" on a flying sail set from the bowsprit a leathered ring with in-out control lines fitted to the bowsprit would be handy for the tack, fairly common on traditional boats.
    Jeff.
  9. Mr.G
    Mr.G Junior Member
    Thanks guys
    Yes she has a new taller mainsail now. The topmast in that picture is now the hounds, and the new topmast is another 9 ft further up.
    I have thought of putting a sliding tack arrangement - but I need to decide on either a yankee style of sail on the front or a light air screecher style first.
    Thanks waikikin.
    Oh yes; what was the furler's halyard at the topmast is now the flying headsail's halyard - there is now no spinaker attachment point - the halyard comes straight out of the masthead sheave.
    Gonzo - there is no furler anymore.
