Small Boat Drag Question....help!
Discussion in 'Boat Design' started by Biomechanist, Oct 30, 2004.
  1. Biomechanist
    Biomechanist New Member
    A quick question about small boat drag. We are using Reynolds Number vs. Froude Number graph to get a drag coefficient to plug into our main equation and find out the actual drang of our boat.
    The problem is that the graph we are using is for huge ships...and so we are getting wrong numbers. We were wondering if someone could get us a graph or a site online that has a graph for Froude Number vs Reynolds Number for smaller boats like kayaks ets.
    We would really appreciate that.
    Thanks
    BioMechanist
  2. tspeer
    tspeer Senior Member
    You don't say what kind of boat you're interested in. Re vs Fr is an interesting approach, but would be highly dependent on the wetted area for the displacement, etc.
    For sailboats, take a look at
    http://www.rina.org.uk/rfiles/HISWA/1996/The bare hull resistance.pdf
    http://www.curtin.edu.au/curtin/centre/amecrc/papers/ame98/bmcrae1.html
    http://www.curtin.edu.au/curtin/centre/amecrc/papers/ame98/bmcrae2.html
    http://www.curtin.edu.au/curtin/centre/cmst/publicat/rinamodernyacht98.pdf
    For slender hulls, see
    http://www.cyberiad.net/michlet.htm
  3. jehardiman
    Likes: 1,515, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    If you are after Cf, why not just calculate it directly with the ITTC line. Or are you trying to use some of Froude's "circle" factors for a given "shipshape" hull? Better to use Taylor's data from a modern re-analysis or one of the standard boat hull series out there if you are doing something small.
