Less is More
Discussion in 'Sailboats' started by CarlosK2, Jan 16, 2026.
  1. CarlosK2
    Likes: 118, Points: 63
    CarlosK2 Senior Member
  2. skaraborgcraft
    Likes: 270, Points: 63
    skaraborgcraft Senior Member
    Some people are lazy. Look at car washes......
  3. CarlosK2
    This
    This cost €12-€14
    I have to do this maneuver ten times and it would cost 120-140 euros, when on top of that it's beautiful and entertaining to do
    The tool used If you go to a nautical shop they might ask for... I don't know, an outrageous amount
    But you can cut a 7 euro knitting needle
    skaraborgcraft likes this.
  4. CarlosK2
    Dyneema rope 4 mm x 60 cm = € 0.7
    Dyneema shackle: € 16
  5. CarlosK2
    In summary
    The safety of a small yacht, between 1 and 10 tons, on high seas does not depend on its size
    Creating different categories (A: Ocean, B: offshore, C: Coastal) of small yachts based on size is ridiculous
    And
    Many yachts sailing downwind suffer from the explosive combination of four elements
    1) with 1-2 people on board, without a large crew, they are very slow in relation to their length, sometimes, often, not even reaching 0.4 Froude and even sailing at 0.3 Froude, and on top of that with the wind right behind them
    2A) Longitudinal imbalance: the center of gravity is forward of the center of flotation, which is where the Pitch axis passes, and on top of that, the wave coming from astern and/or the heel moves the center of flotation even further aft
    center of flotation calculation and implications? https://www.boatdesign.net/threads/center-of-flotation-calculation-and-implications.30857/
    And to top it all off, the vertical component of the wave force is applied to the center of flotation or, if the yacht is not tiny, aft of the center of flotation
    Conclusion: rapid and/or deep Pitch
    2B) And furthermore, when the yacht heels, the center of buoyancy moves aft, meaning the bow drops, for example by one degree, something known since 1880: "heavy quarters"
    3) Two degrees (-2°) of bow down is enough to drive Mr. Max Michael Munk crazy
    On a yacht, we can encounter three versions of Munk's Moment
    A) due to leeway/yaw
    B) due to leeway/yaw + roll/heel
    C) due to leeway/yaw + roll/heel + pitch
    And
    Munk_C = aprox. => 2 x Munk_B
    4) To make matters worse, the hydrodynamic center of a very efficient modern Keel is located forward of the yacht's center of gravity, where the Yaw axis of rotation passes
  6. CarlosK2
    and
    5) the orbital current of the wave
    If the yacht is sailing at 7 knots and the orbital current of the wave is 3 knots, the water flow at the rudder blade is 4 knots and at the bow of the yacht is 7 knots, or the rudder blade feels 7 knots and the bow 11 knots, and in the worst case the rudder blade feels 4 knots and the bow 11 knots, and in any case the forces depend on the square of the speeds
  7. CarlosK2
    A 1-ton, 5.99-meter WindSurf board Plywood Epoxy ...
    I think it's the smallest possible yacht ... and the biggest dinghy
    An ideal boat for 1 old sailor, which would also be the ideal boat for 1 young ocean adventurer
    An old-man's boat, a kid's dream boat
  8. tane
    Likes: 134, Points: 43, Legacy Rep: 10
    tane Senior Member
    & your malevolent neighbour can cut it with a pocket knife...
  9. CarlosK2
    Experience, numerical calculations, and the Southampton wave tank all agree on the diagnosis:
    The bow dips, then the hull's yaw moment (the Munk moment) skyrockets, and to top it all off, a keel trips the yacht.
    The helmsman is exhausted, the autopilot fails, the yacht lists to regain its balance like a boxer knocked down on the canvas, and dishes fly around in the galley. In short: no enjoyment.
  10. skaraborgcraft
    You have convinced me........perhaps i should take up fly fishing?
  11. CarlosK2
    Eric Sponberg ... Bagatelle
    Bagatelle https://ericwsponberg.com/boat-designs/bagatelle/
    Incredible, amazing, what a marvel !
    Achieving 20 square meters per ton is extremely difficult or incredibly expensive beyond 6 meters in length
    The law of the square and the cube is relentless with sailboats
    And the Mini Transat-type solution with a gigantic beam compromises passive safety: let's not forget that current Mini Transats cross the Atlantic... accompanied by adults
    A small boat in which I would feel at ease at home if a nephew, son, or grandson were sailing alone
    Speed is safety because it allows you to sail in harmony with the waves
  12. CarlosK2
    Andrew Claughton
    Racing on the high seas: leading yacht designer reveals engineering challenges behind the America's Cup | University of Southampton https://www.southampton.ac.uk/news/2007/11/yacht-designer-reveals-engineering-challenges.page
    (I'm including this link because I can't find a better one)
    Southampton Wave Tank
    - "the traditional design was quite easy to control [radio-controlled models] (...) the ease of planing and control in the traditional models was a striking surprise"
    Experience, numerical calculations, and the Southampton wave tank ...
    All agree on the same diagnosis:
    A yacht is sailing slowly, its bow dips, Mr. Max Michael Munk goes completely mad (Hull hydroDynamic Yaw Moment)
    Max Munk - Wikipedia https://en.wikipedia.org/wiki/Max_Munk
    And to top it all off, the yacht hits a massive modern Keel, flips over, and capsizes.
  13. CarlosK2
    A small boat, and therefore with enough power to sail at 0.5 Froude and "create hydrodynamic Lift at the bow" (Andrew Claughton) and with "neutralized Keel" (CarlosK2) is a good idea
  14. CarlosK2
    + 2°
    A still photograph captures the moment when a Ocean Wave carries the small boat away in its powerful arms.
  15. CarlosK2
    1) We've sent Mr. Max Michael Munk to bed to sleep peacefully: there are no lateral high pressures at the bow, and with a wide stern and the water flowing straight out without curves, no lateral low pressures are created
    2) The enormous centerboard is neutral; its gigantic lateral force (if the boat yaws at high speed) has no leverage arm, or the leverage arm is minuscule because its hydrodynamic center is located below the longitudinal position of the center of gravity
    3) With stable balance on all three axes (Roll, Yaw, Pitch) two good, well-sized rudder blades only have to compensate for the imbalance created by the sails
    4) The boat can fly at the Wave Celerity in harmonie Surf riding the Ocean Wave
