Less is More
Discussion in 'Sailboats' started by CarlosK2, Jan 16, 2026.
  1. CarlosK2
    Likes: 118, Points: 63
    CarlosK2 Senior Member
    This morning I came to the following conclusion:
    Dinghy sailboats tend toward rationality because they were rooted in the working class
    Sailing yachts come from a tradition of extravagance, large crews, and many people working for you—a world not just of millionaires, but of billionaires; the higher you go, the more extravagant.
  2. CarlosK2
    Eric Hiscock ...
    A century ago, it seems the combined strength of the shrouds could withstand 1/3 (!?) of the yacht's displacement
    Today, we ultimately calculate that one shroud can withstand the displacement at maximum load
    Why weren't more rigs breaking in 1925 ?
    I imagine it's due to the flexibility of the assembly: wood masts, cables, and turnbuckles
    I can't find any other explanation
  3. CarlosK2
    It's shocking how much these things cost, and this is just the small one for 2-5 mm lines; the larger one is outrageously expensive
    So instead of 6 mm line with a Dyneema core... 5 mm of pure Dyneema
    There are very cheap gadgets for tennis racket strings and bicycle spokes; but I don't think they'll work for me.
  4. CarlosK2
    On the other hand, I've seen that Starlink Mini is affordably priced: €250 for the device and €40 per month for coverage up to 12 miles offshore. The antenna measures 30 cm x 25 cm
    And the installation is simple: cut the flimsy cable it comes with, and increase the voltage from 12 to, for example, 30 volts.
  5. skaraborgcraft
    Likes: 270, Points: 63
    skaraborgcraft Senior Member
    Lanolin.
    People are expected, more so by insurance, to replace stainless rigging every what 10-20 years?
    Galv wire rope will last longer, BUT, it does need to be maintained. The great advantage, you KNOW when it should be replaced.
    Having lost a forestay mid-Atlantic at a fitting that looked almost "good as new", I am very wary of old stainless.
    My internal jury is still out on dyneema......
  6. skaraborgcraft
    Yes, starlink is a must so you can continue to watch youtube and post to forums while sailing to the Azores.
    Tech has become absurdly cheap compared to past options.
  7. CarlosK2
    "Lanolin"
    "the threads of galvanised steel rigging screws (...) I used lanoline (...) but it is not a lubricant"
    Eric Hiscock
    Maybe ... white lithium grease
    The great utility of the Starlink Mini, in my opinion, lies in its access to Google's satellite map, which, very close to the coast, surpasses any other cartography, plus its general communication uses.
  8. CarlosK2
    The problem with Dyneema
    was that you couldn't tie knots because it would slip, but ingenious knots have been invented. Even so, tying a knot reduces the breaking strength by 50%
    The other problem was degradation from sunlight; now they're sold coated with a protective layer, like paint, and anyway:
    A) they're so strong that nothing would happen if the outer layer degraded, and
    B) it's very very easy to replace, and 5 mm is cheap
  9. CarlosK2
    35 cm inside (= 70 x 5 mm) plus the section (taper) of, for example, 15 cm where it gradually narrows by cutting threads until only one thread remains.
    This is to prevent it from breaking abruptly at the step formed.
    It's also important to prevent it from coming loose when there's no tension.
    There are several methods.
    I like the idea of sewing it with a fine thread and protecting the fine thread with adhesive tape.
  10. skaraborgcraft
    I will have a free standing mast, but like the luggers of yore, the yard halyard can be doubled to a block and made off aft on the opposite side of any chute i would deploy in lighter weather.
    The easy splicing of dyneema is certainly a feature, but i never had any simple "Flemish eye splice" in wire rope slip either.
  11. skaraborgcraft
    Your rigging loads on your 1 ton surfboard will be much higher. I could probably get away with pre-stretched polyester. Not done a price comparison for many years. The rope is certainly eaiser to stow than wire.
  12. skaraborgcraft
    Rather than use wire, i was debating using dyneema as a luff rope for a furling headsail. Much easier to sew the sail to dyneema. Not so sure about excessive twist when furling.
  13. CarlosK2
  14. CarlosK2
    "going soft on shackles" (practical sailor)
  15. CarlosK2
    What I don't understand is why they are so expensive if they are so easy to build nowadays with so much information available
