Seaworthiness is the result of all the parts of the design. Length alone is not a dominant factor. 10 feet is a beam that can make for a roomy boat. Doubling the length, with all other dimensions the same, will double the stability. Seaworthy in itself is not a defined quantity. You need to first define the aspects that fulfill what seaworthiness means. I have cruised small boats in storms and survived. Others abandon boats and ask for rescue, largely due to the discomfort and misery of surviving bad weather. The weather conditions and area of operation also define seaworthiness to a large extent. Start a Statement of Requirements (SOR). This will drive the design. There are two main categories. First are the constraints, they are hard restrictions that can't be changed. For example, the 10 foot beam. The requirements are functions that need to be met. For example, able to sail to weather in a storm in the open ocean. The way requirements are met can be changed or modified within the constraints.
