Least Square Method (linear) - Freeboards and drafts
Discussion in 'Education' started by Transom6.3, Sep 22, 2009.
  1. Transom6.3
    Transom6.3 New Member
    Hi Guys,
    I have seen the least square method (linear) in a number of inclining test reports when used to get the inclined waterline from a number of freeboards measurements and drafts.
    I have no idea what the formula/process is, does anybody know?
    I realise there will never be a perfect straight line through all the freeboard measurements so this method must average the differences out.
    Thanks for help.
  2. Ad Hoc
    have you looked at the ISO code?
  3. Raggi_Thor
    It's a lot of work to do this math manually.
    Say you have measured some heights (y1, y2, y3 etc) at some given locations (x1, x2, x3 etc), then find a straight line Y = ax + b (calculate the constants a and b) so that the sum of the squared differences between all your measurments and the calculated Y is minimized.
    Excel or OpenOffice does it for you.
  4. Transom6.3
    Thanks guys,
    I'll look into it and try and set up an excel spreadsheet.
    Does anybody have an excel template.
  5. Raggi_Thor
  6. Raggi_Thor
  7. Transom6.3
    Thanks alot Raggi,
    That's a big help.
