Leaking Engine Exhaust Manifold / Riser in a Volvo GXi-E
Discussion in 'Inboards' started by SuenosAzules, Feb 14, 2016.
  1. SuenosAzules
    Likes: 3, Points: 0, Legacy Rep: 18
    SuenosAzules Junior Member
    I always like to share things that I find in the field that I think are important to boat owners so they may see some of the tell-tale signs so they avoid costly repairs later down the line.
    Below is a link and some photos of what happens when an exhaust manifold leaks sea water back into the cylinder via an open exhaust valve. This particular engine was a 2004 Volvo GXi-E six cylinder, 225 HP, gasoline inboard engine attached to a Volvo sterndrive. This was an actual inspection I conducted for a client last week. I took photos to document the findings.
    The entire article I wrote is at the link below:
    https://www.linkedin.com/pulse/thermal-imaging-troubleshooting-leaking-exhaust-volvo-banister-ams-
  2. Boat Design Net Moderator
    Likes: 188, Points: 43, Legacy Rep: 1004
    Hi John. The link in your post appears to be incorrect. Can you post the correct URL?
  3. SuenosAzules
    Link Working..
    Okay link working. Sorry fellas.
