Lcb / Lcg
Discussion in 'Powerboats' started by Mat-C, Apr 27, 2010.
  1. Tad
    Likes: 214, Points: 73, Legacy Rep: 2281
    Tad Boat Designer
    Matt...
    Ah......yes.....you are right as far as you go.......but......
    LCB is just that....the center of a volume......it does not define how the volume is actually shaped...
    CP (prismatic coefficient) is the other part of this puzzle......
    Low speed hull.....fine ends and fat middle, low prismatic, forward LCB.
    High speed hull....fuller ends and slimmer middle, high prismatic, aft LCB...
    Simple....
  2. Mat-C
    Likes: 12, Points: 0, Legacy Rep: 141
    Mat-C Senior Member
    Hmm...well, as always, that makes sense...:)
    But I'm still not sure as to why I keep seeing references to keeping the LCB forward in order improve low speed planing performance... if what I said in my previous post was essentially right....
    In thinking about it, I can see that for a typical v-hull of say constant deadrise, increasing the CP is also likely to move the LCB forward.
    In looking at your article (that you linked to before) you note that there is an ideal CP for each S/L. You go on to give a range for a few S/L's...
    I hate to ask, but is there a graph that show the ideal relationship between these two?
