Large Angle of Stability with Maxsurf
Discussion in 'Stability' started by Chriss95, Jun 3, 2024.
  1. Chriss95
    Chriss95 Junior Member
    Hello, i'm a engeenering student, i was trying to run a stability analysis with maxsurf and i was wondering if as a data imput i need to insert deck bride or only hull is fine ?[​IMG]
  2. TANSL
    In Maxsurf you have to do exactly the same as if you calculated it by hand.
  3. Chriss95
    Ok, so i don't need a deck surface on model ? i was wondering for freeboard calcs
  4. TANSL
    What you need if to clearly define the volume that serves as buoyancy reserve.
    Talking of Maxsurf, if you have an open space, the application tries to close it. So, probably you don't need the deck but you need to perfectly define the sheer line.
  5. Chriss95
    Thank you so much, i guess sheer line is auto detected on maxsurf, my doubt was whether it was possible to have a vanish stability angle of 110 deg (it's a planing hull Lwl=12m, Bwl=4m)
  6. TANSL
    I don' t thing possible a so huge angle. How is your boat?. Should have a watertight superstructure. Then you do need to define deck and sp.
  7. Chriss95
  8. TANSL
    The righting arm curve shape seems correct but its maximum value and the maximum GZ angle are, imo, very high. I think the avs is too big, under normal conditions it should be less than 90ยบ. However, with the data you show us I can't say anything more. Check the weight calculation carefully, as it is possible that your CoG is too low.
  9. Chriss95
    i will, many thank's for your help !!!
