Village_Idiot
Senior Member
- Joined
- Oct 19, 2007
- Messages
- 382
- Reaction score
- 18
- Location
- USA
We use a landing craft on a smaller scale (with around 3-4000lb load). When unloading the LC, we anchor it in place (spud anchor at the bow gate, plus anchors from the stern going each direction to land). The bow anchor prevents fore/aft movement, and the stern anchors keep the stern from shifting to either port or starboard. We then unload and keep the LC in place.
Upon re-loading the LC, we are far enough from shore that we can usually back off with little problem. This LC has an outboard (150 Merc), and since it is flat-bottom, I designed it to have square front, rather than a mod-V bow. Therefore, we are able to wiggle the stern to port/starboard and that process will "walk" the bow off of the shoreline. This cannot be done with a pointed bow (although it could be done if you drop two push bars off the bow, on either side).
Btw, if you do use a winch, keep in mind that you can double (or more) the pulling power with a block-and-tackle, when needed.
Another option is to have a second boat on hand to help pull the LC from shore - use two tow ropes, or a double-ended V- or Y-bridle.
