Note: This feature may not be available in some browsers.
You'd have to have a lot of faith in the strength of that windscreen to do that!!
Thanks for that very comprehensive reply, It;s really appreciated and has given me plenty to think aboutInstallationwise I'd prefer the jet, since it has both steering and reversing integrated, just connect with a driveshaft (but that one should be correctly dimensioned and balanced). The 90-jet weighs about 60 kg plus IIRC 20 kg of water, while the 100 comes at about 135 kg in total. The jets are "nicer" to the engine, as their required power is practically unaffected by boat speed, while a propeller with a heavy load at low boat speed will overload the engine.
It also has an operating edge over props in this kind of vessel, where your propulsion must function from deep to shoal waters AND have positive steering vectoring 360 degrees down to zero speed.
If you go for a propeller installation, the weights might come out slightly less, but you've got a separate drive-shaft (since fwd/reverse transmission cannot be directly attached to engine), tranny with correct gearing and cooling, propshaft with gland and shaft bracket with wet bearing, all to be mounted with close tolerances, and on top of that a rudder arrangement with stock, bearings and operating paraphernalia. An alternative prop drive is of course an IO leg, but then there are other problems, weight and draft incuded.
The question for the propulsion is if you can use a PTO and what rpms available there, or how the drive can be arranged.
