Hi all, a total newbie here...so please play nicely
I'm in the very early stages of designing an amphibious vehicle and looking at the feasibility of using a PP65 jet drive via a transfer box 'power take off' unit.
It will be based on a Land Rover Discovery 1 300TDI which has 111 BHP at 4000 RPM and 195 lb-ft (265Nm) of torque at 1800 RPM. The vessel will be a maximum weight of 2700KG.
The hull will be 6m x 2m and approx two thirds of the wheels will remain in the water.
Now, I know this is very much a 'how long is a piece of string' type question but would like to know if you think this set up could possibly achieve 6 knots without the engine running flat out? Very few amphibious vehicles (without retracting wheels) achieve more than 6 knots anyway but I would happy with this speed as a minimum.
I know that there are so many variables that you would need to make accurate calculations but at this stage I don't have those figures and so just looking for what you suspect would be the case. Also, if it is a possibility then which would be the most suitable sized impeller?
If I am way off the mark then what would you suggest as a more suitable (and relatively cheap) alternative to a PP65?
Thanks very much for your time
Regards
Chip Wilson
Southampton UK
Regards
Chip Wilson
Southampton UK
