lamination schedule help
Discussion in 'Fiberglass and Composite Boat Building' started by brokensheer, Aug 8, 2010.
  1. brokensheer
    Likes: 3, Points: 18, Legacy Rep: 14
    brokensheer Senior Member
    I am thinking about buying an existing mold I have no history on the construction or laminate schedule. Would anyone here be willing to work with me in help to develop one. I plan on building it as a solid glass(ex transom) hull as its a 17' boat outboard power and it will have a cored transom
    I have other measurements, Thanks!
  2. tunnels
    tunnels Previous Member
    Making a boat is not a problems but will need more info and some pictures of a boat along with some measurments , also what size motor is intended to power the boat ? Need pictures !!:eek:
  3. Landlubber
    Landlubber Senior Member
    brokensheer,
    One easy and efficient way to do the extension is simply get sheets of Lamipanel (Corian or Laminex maybe to you) and screw them onto the current hull. They need bracing to follow the exact line of th ehull, but they do so remarkably easy. Do a nice job of the V bottom joint, seal with kids plasitcene (putty) and them gelcoat the insides, followed by the laminate. The old transom is not gelcoated, and the structure is built up direct to it (after stripping off the gelcoat around the edges. You cannot laminate over old gelcoat. The new transom is added of course to the ends of the panels.
    No mould is needed then of course.
  4. SamSam
    SamSam Senior Member
    Landlubber, wake up! You are dreaming! This is the wrong thread!
  5. brokensheer
    Chine Beam Transom: 78.5
    Chine Beam at Sheerbreak: 77.125
    LWL: 170
    LOA: 206
    Target Displacement: 2200
    Wetted Surface Area: 77 sq. ft.
    max HP 115
  6. Herman
    Herman Senior Member
    Are you serious about the displacement???? In ounces, I presume?
    You make me curious about the boat. Do you have pictures?
  7. brokensheer
    no pictures and the displacement is in lbs.
  8. Landlubber
    Sam Sam......sorry mate......working too hard ....i will take the red pills today to try and wake up to reality.....
  9. tunnels
    No pictures is not good !! even a few drawings as to the shape etc
    So it will be all guess work ! Have you had a schedual of the glass for a equivlent type of boat ? With a 115 motor what kind of speed do you sort of expect to do ? Thats also another factor as to what where and what type of glass you could or should use !!. :confused:
    Not trying to Fob you off just need more info to get a better idea as every one else will be wondering as well . ;)
  10. brokensheer
    Thanks all I got it covered!
  1. Gypsie
  2. adam_designer
  3. Sea Jay
  4. Evelyn 32
  5. Flork
  6. jangr
  7. mrybas
  8. LowelandSystem
  9. JINLEE
  10. rawleyjerel@yah
