Laminating Polystyrene to Ply
Discussion in 'Materials' started by tmark, Feb 5, 2016.
  1. tmark
    Likes: 5, Points: 8, Legacy Rep: 60
    tmark Junior Member
    Okay folks ... let's just say I wanted to bond polystyrene (those pink of blue insulation sheets sold in big-box stores) to a sheet of BS 1088 ply ... what should I use?
  2. Ebeneezer
    Ebeneezer Junior Member
    I have made several interior panels like this using epoxy. Sand the surface of the foam with a 80 grit belt and walk on with a pair of golf cleats to create hundreds of good bonding holes. I then vacuum the sheets of ply on both sides at once.
  3. tmark
    tmark Junior Member
    Gotcha ... thank you.
  4. upchurchmr
    upchurchmr Senior Member
    Epoxy works.
    So does Titebond 2.
    Helped my wife make a table out of 4" foam and ply to stiffen the legs.
    Takes a while longer than normal to "set".
  5. PAR
    You don't need the holes, if using epoxy on these types of low density foam. It just increases epoxy requirements.
    TiteBond II is only water resistant, so consider TiteBond III instead if it'll be in a very humid or an occasionally wet/immersed environment.
  6. Tungsten
    Tungsten Senior Member
    PL 300 is for foam.
  7. tmark
    tmark Junior Member
    Thx Tungsten, are you also able to say how long it takes to to cure?
  8. Tungsten
    No idea, but it sticks and stays in place while you glue up more.
  9. upchurchmr
    tmark,
    What are you going to do with this lamination?
    Just interested.:D
  10. philSweet
    Likes: 639, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
    Odd pair of materials to be bonding together. I've done that once when I replaced the foam floor in my dinghy. I glued eps foam boards to the 6mm bottom on my dinghy for flotation and protection from dropping stuff through the bottom, like 60# anchors. I used gorilla glue to stick the replacement foam to the previously epoxied hull. Two layers of foam and a top layer of 2.5mm ply. Then I glassed the edges and draped 9oz cloth. Not a lot of hours on it yet, so I don't know how it will do.
  11. tmark
    tmark Junior Member
    Why, just experimenting my dear Mr Church. :)
  12. upchurchmr
    I don't usually allow Mr.
    But my name is Marc Richard Upchurch, so as an enlisted instructor in the navy I signed MR Upchurch making the Ensigns upset. If they persisted I put the periods in there.
    The Lt. Commander who was an student of mine just laughed at me, which was what was appropriate :D
  13. Steve W
    Likes: 94, Points: 48, Legacy Rep: 608
    Steve W Senior Member
    I have built a few panels, hard dodger top and cockpit sole, using resorcinol many years ago but I included a cedar perimeter and stringers for reliable bonding. I think today I would use the PL300
  14. PAR
    PL300 isn't very good on dynamic loads, but is suitable for static. It's also not waterproof, just water resistant and it's "creepy" under load.
