Laminating plywood to freeboards
Discussion in 'Wooden Boat Building and Restoration' started by janbo2, Aug 9, 2012.
  1. janbo2
    janbo2 Junior Member
    Thanks all boat builders out there for your continuous help with our project. Now for some more questions.:)When laminating 6mm and 9 mm ply to the free boards, which thickness should go on first? Do we use just epoxy resin to laminate, or should we add a filler to it to get a glue like consistency?
  2. rwatson
    Likes: 537, Points: 113, Legacy Rep: 1749
    rwatson Senior Member
    Probably just easier to lay the 6mm on top of the 9mm, as the 9 mm is heavier, but it doesn't really matter. The thicker ply can ensure a bit flatter result, depending on what you are laying it on.
    You can use straight epoxy, but for a really top job, they recommend thickening it to ketchup thickness , with say, 50/50 microballons and cabosil, to make sure that no resin runs out of position, leaving a void. Quite a few people will drill 1/8" holes at say 1' distances to ensure they get a visible goo oozing out over the panel.
  3. janbo2
    Thanks for that, Rwatson, we will try that tomorrow!
  1. robwilk37
  2. newsailer
  3. JohnMcC
  4. Brian Fredrik
  5. CaptChap
  6. NorthLakeFisher
  7. AwJees
  8. sdowney717
  9. Sunburned One
  10. sdowney717
