L20 Beach trimaran
Discussion in 'Multihulls' started by Corley, Aug 28, 2012.
  1. Corley
    Likes: 199, Points: 63, Legacy Rep: 826
    Corley epoxy coated
  2. Doug Lord
    Doug Lord Flight Ready
    L20
    Another ,"modern", damn good looking small tri w/o foil assist. It amazes me....
  3. Corley
    Corley epoxy coated
    You should jump into the thread on pinoy.boats and suggest it Doug. They had quite an interesting discussion in there about home built beams, hulls and masts they would probably like discussing foils too particularly the home made type.
  4. Doug Lord
    I read part of it and the designer likes the concept of a submersible ama as a way to depower, if I understood him correctly. So be it.....
  5. Corley
    Corley epoxy coated
    I dont necessarily think the two concepts are incompatible. A low buoyancy float matched to foil assist could be a really nice combination and save weight as well particularly on a small trimaran. It would just be tricky to decide how to distribute the volume, you would probably just focus on minimum rocker, keeping the volume low to the waterline to try and keep pitch under control and minimise drag and maybe a T foil rudder? It would be an interesting project.
  6. Doug Lord
    Low buoyancy amas with foil assist is the way to go for a high performance, beachcat killing trimaran, in my opinion. I'd design the ama for intermittent contact with the water and use a single, retractable, curved lifting foil. The main hull would have a wand controlled lifting foil on the daggerboard and a rudder t-foil. That would allow a wide tri to fly the main hull in light air and the two main hull foils would control pitch in the toughest conditions. The faster the boat goes the more the main foils unload and resistance drops.
  7. Gary Baigent
    Gary Baigent Senior Member
    Excellent find, Corley. These blokes are on the RIGHT track. Just imo of course.
  8. Corley
    Corley epoxy coated
    Yeah I liked their home build focus of the design and the wingmast discussion. It's pretty cool to see people building things and testing out ideas.
  9. samaloutrigger
    Likes: 3, Points: 3
    samaloutrigger New Member
    I apologize to bring up this old thread. I just want to redirect the broken link from the original post to a another website of the L20 Trimaran, to www.samaloutrigger.com
    A boatplan is also available at WoodenBoat.
  10. upchurchmr
    upchurchmr Senior Member
    Nice looking boat, except for the very low displacement amas.
    I don't think this would work well with the Tornado rig and such low ama volume when the effective beam (seated position vs ama) is the same as a Tornado ~10'.
    I bet it trips quickly over the lee ama bow.
    Of course, pasting on a foil can solve everything. That was a little sarcasm. Perhaps the akas will need to be increased in size for "flying".
    And putting reverse bows on the boat will automatically make it more "wholesome".
    Perhaps we should see it sailing.
  11. samaloutrigger
    Likes: 3, Points: 3
    The Tornado rig will submerge that ama over 20knot wind. More than that, this is how we sail a boat with very low displacement Ama and big sails;
    Doug Lord and rwatson like this.
  12. rwatson
    rwatson Senior Member
    Great to watch. They should make that "class" worldwide. Home-built, innovative and exciting to watch.
  13. Lurch723
    Likes: 15, Points: 8, Legacy Rep: 10
    Lurch723 Junior Member
    I think the key thing here is to use more crew weight to balance the boat as with my boat, it's quite surprising how well this amount of bouyancy will work with that long lever arm, giving the crew plenty of time to either move further outboard or dump some power from the main sheet. But your quite right the high aspect ratio of the rig will tend to push the bow down under acceleration. Great looking machine though, I'd have one if I hadn't already built my own, it looks really well proportioned and balanced.
  14. upchurchmr
    Now that is some pure sailing.
    Thanks for the video.
    Makes what's done around here seem pretty tame.
  15. samaloutrigger
    Likes: 3, Points: 3
    It's my pleasure to share the video of our Paraw traditional sailboat. The concept behind the L20 Trimaran is based from Paraw.
    The 22 sq.m sail area of L20 Trimaran is really meant for leisure sailing at less than 20knots of wind. What seems to be low displacement Ama from a "multihull world" point of view, is actually more than plenty from our perspective (outrigger world). We love to bring friends or family (as moving ballast) to enjoy sailing and the seascape as well.
    Doug Lord likes this.
