KN Calculation
Discussion in 'Stability' started by toy, Oct 6, 2012.
  1. toy
    toy New Member
    Anybody can help me how to manually calculate/produce KN Values in every Displacement and in every 10 degrees heel increment needed for stability booklet.Thank you.
  2. Adeyele
    Adeyele Junior Member
    Helo Toy, re u studying IIMS course?
  3. toy
    toy New Member
    Hi Adeyele, planning to make stability booklet.
  4. chandru447
    chandru447 Previous Member
  5. Adeyele
    Helo toy, am nt planing to make any1 but I have a exercise relating to your question.
    Its exactly as your question.
  6. cyro
    cyro Junior Member
    Find GZ first.We know that relation between GZ=KN-KGsin(theta)..GZ=GMsin(theta) .But it is true for angle between 0and 5degree.7degree is maximum.For larger angle of heel,use Barne's method.
  7. conceptia
    Likes: 7, Points: 0, Legacy Rep: 97
    conceptia Naval Architect
    Normally we use software to calculate KN and we generate GZ curves right? How is the other way working?
  8. cyro
    cyro Junior Member
    Atwood's formula.It will take 4 hr to complete one curve.
  9. chandru447
  10. en360
    Likes: 2, Points: 0, Legacy Rep: 42
    en360 Junior Member
    Since I use software to calculate KN, forget it
  11. Julien_C
    Likes: 1, Points: 0, Legacy Rep: 33
    Julien_C New Member
    You need to:
    1. Section your boat
    2. Calculate the heave a trim for a given heel angle so that the integral of immerged surface area of the sections gives you the proper volume and LCB
    3. Calculate the position of the centre of buoyancy using a barycentre calculation
    4. Use trigonometry to find KN
    Unlike someone said earlier, you don’t calculate GZ first then KN but the opposite. A stability software always calculate KN first then derives GZ. Remember that KN represent the form stability. Which means that once you have your KN curves you can derive your GZ curve for any VCG you like.
    The KN curves isolate the form stability from the mass stability.
