Kevlar canoe
Discussion in 'Boatbuilding' started by AK44, Sep 24, 2019.
  1. AK44
    AK44 Junior Member
    Hello,
    I'm looking for technical advice from people having experience working with composites.
    I plan to make kevlar canoe. The plan is for 18' canoe 3 or 4 layers with vacuum epoxy infusion.
    But I recently got over pretty inexpensive kevlar sheets 3 ft x 5 yd pieces.
    Which means it will be made from many pieces.
    How is from your experience, how much it may affect hull strength?
    Is it worth to consider making it from pieces or better not to take a risk and go with one piece per layer?
    Thank you for your time!
  2. jehardiman
    Likes: 1,472, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    More important than the material is....what is the weave?
  3. AK44
    AK44 Junior Member
    It's actually good question. Unfortunately I don't know wave because it surplus from other guy client and they do not have info.
    What waive should it be?
  4. AK44
    AK44 Junior Member
    Or better say, what wave won't work?
  5. jehardiman
    Should be linear or satin weave if you are going to use it for structural shapes, otherwise the resin will be the only strength. Most typical Kevlar "fabric" is designed to exploit some other property of Kevlar (i.e. cut resistance, fire retardant) while still giving good flexibility and draping.
  6. AK44
    AK44 Junior Member
  7. jehardiman
    In building a lightweight canoe or other narrow open shape, it would be preferable to use a fabric with greater linearity and less crimp. Ideally, there would be continuous stem to stern fibers without crimp (Crimp is the bending of the warp fibers over the weft fibers). So from a strength to weight perspective linear>satin>plain. However, while plain weave has lower mechanical properties (due to the crimp and more resin fill), it does build thickness faster and has slightly better cross axis impact properties. As long as the Kevlar fabric is intended for composite construction and you stagger the butt joins, it should be acceptable, if a litter heavier. A quick Google gives the following summary of fabrics
    Woven Fabrics https://netcomposites.com/guide/reinforcements/woven-fabrics/
    or you can use the old Gibbs & Cox Marine Design Manual
    https://ia800205.us.archive.org/20/items/marinedesignmanu00gibb/marinedesignmanu00gibb.pdf
  8. AK44
    AK44 Junior Member
    As far as I understand in case of satin warp should go along the canoe hull.
    And cross axial impact won be affected much?
    Am I correct?
    Sorry, but I still cannot get what is linear weave?
    I have not read yet Gibbs & Cox Marine Design Manual, but woven fabrics not listed it.
  9. jehardiman
    Realistically, the hull is going to be a minimum of 4 layers 0,+45,-45,0 where 0,+45 and -45 are the angles of the warp to the main stress axis (for a canoe generally along the keel and gunwales). With plain weave this layup won't have much change on strength. The outermost ply is always going to be the heaviest loaded, whether in tension or compression. If you are really worried about impact from the outside of the hull, you could try a <outside> 0,90,+45 -45 <inside> layup.
    Linear or Unidirectional fabric is a fabric where there is a preponderance of warp fibers with few or lighter weft fibers. These fabrics are very sensitive to stress axis, but provide better performance if used properly.
  10. AK44
    AK44 Junior Member
    Thanks for advice it really make sense. But also as far as I understand for plan weave orientation does not matter?
    The plan is for now: first layer of fiberglass, second layer of full length kevlar, third layer of partial kevlar sheets, 3/8" foam core complete bottom and ribs on sides and on top of foam kevlar sheets. How all of it sounds for you?
    Also foam density - will 4lb works for the application?
  11. AK44
    AK44 Junior Member
    Can you please advice on fiberglass.
    I plan to use it for outer layer of canoe.
    1 layer fiberglass - how much oz should it be?
    2 layer kevlar 5oz
    3 layer kevlar 5oz
    4 foam on bottom and ribs
    5 kevlar over foam
    I'm trying to keep it light
  12. Dejay
    Likes: 138, Points: 43
    Dejay Senior Newbie
    I might be wrong but I think kevlar/aramid on the outside is better because it improves scratch resistance.
    5 oz/yd² equals 170 g/m² but I have no clue about typical layups.
  13. AK44
    AK44 Junior Member
    There is different reason for first fiberglass - it can be sanded, while kevlar will felt.
  14. jehardiman
    The problem with that layup is that it is unbalanced. Most likely will fail between the foam and the inner skin. A second layer on the inside will help.
  15. AK44
    AK44 Junior Member
    I know what you mean, but seems like it's pretty much standard canoe layup.
    There is from Savageriver:
    The Dual Kevlar layup consists of a fiberglass skin for abrasion resistance, backed with two layers of Kevlar for puncture resistance, and a foam core with another layer of Kevlar over the core.
    I'm trying to make something similar to there blackhawk canoe.
    http://www.savageriver.com/canoes/recreational/blackhawk
    One more question about core: how dense should it be and how thick, any recommendations?
