mojounwin
Junior Member
- Joined
- Dec 30, 2004
- Posts
- 77
- Reaction score
- Location
- Queensland, Australia
Hi Folks,
I'm after some advice regarding a new keel.
It's for a Hartley 16, which is a 5m trailer sailer. Upwind speed would be about 5kts.
The original keel is a steel plate, 10mm thick. The plate is about 1000mm deep x 450mm chord. It's just a flat plate, no foil shaping.
I want to build a new keel about 1200mm deep. Naca 0010. Strip plank timber with the bottom half lead.
Upwind sail area is about 18sqm.
Any ideas on what sort of area the foil should be. I'm guessing I can get away with a small keel then the existing as presumably a proper foil is going to be better then a plate.
Cheers
Mojo
Cheers
Mojo
