fallguy
Boat Builder
- Joined
- Dec 7, 2016
- Messages
- 8,938
- Reaction score
- 2,093
- Location
- usa
I'm not going real far on this, but the idea the floors would break on the ends first from the keel pressure is false. The keelson is probably a bit round. This means the greatest movement is at the middle. Make a c shape with your hand and thumb and forefinger and move your elbow as the keel; the hand moves through a greater range than do the fingers. The fingers basically stay in one place. Had the floors cracked further out; you probably would have lost the boat. They saved it..perhaps..
I do think the hull is probably fine, but I cannot in good conscience suggest you don't have a surveyor look at it. Nor can I support the idea of not repairing broken floors. Nor do I agree those cracks are not a direct result of the keel bolts being unsound and pressure from the keel acting on the keelson and hull unevenly. The keelbolts, if rotten in the middle as they appear also explain the cracks through occam's razor, the keelson is rotten here, the floors did too much work, etc.
I am sorry to tell you, but posts like yours are not well received on the forum. Most of the better trained members avoid posts where they become concerned about liability a/o if the poster seems like they won't listen. The last thing anyone here wants is a tort claim after 3 people drown on a boat because someone jerry rigged a repair, not to mention the frustration of an owner in denial about floors cracking, etc.
See if @kapnD replies here again or is willing to comment on the floors being cracked.
The floor I blue arrowed at the bottom looks like has had other maltreatment or has other holes plugged. This would also weaken it and help it crack under keel pressures. It needs replacement I'd say unless the patches are fooling me. They could have even contributed to the cracking. Not all that hard to do the floor repairs really. If you don't believe the timbers cracked or are deficient, grind the mat and resin off the tops and inspect.
Where is the boat? I am in Inver Grove and slip at SPYC in a month or two.
By the way, the floors do not look like they were ever that strong, on this we agree. So if you redo them, you may consider making them a bit higher.
