jute rope
Discussion in 'Boat Design' started by montero, Mar 2, 2025.
  1. montero
    Likes: 85, Points: 28
    montero Senior Member
    4m lenght 4 centimeter diameter jute rope . Best way to make loop at the ends.Save lenght.
  2. Waterwitch
    Likes: 51, Points: 28, Legacy Rep: 20
    Waterwitch Senior Member
    Eye splices are used.
  3. jehardiman
    Likes: 1,515, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    That is a pretty big rope to be made out of jute. Are you sure it isn't manila? There will be strength and splicing issues with a jute rope that size.
    As to how you handle it; depends on what you mean by "saving" the line's length. If you wish to make a permanent eye strap pendant, then use eye splices. If you need a line that has an eye where you need it, then sew a seizing on the ends and use a tight bowline. There won't be that much difference in length between eyes or strength, but if the material really is jute, kotting and re-knotting can become problematic. Jute shrinks, abrades, and degrades very quickly when wet, which is why manila is preferred.
  4. Will Gilmore
    Likes: 533, Points: 113
    Will Gilmore Senior Member
    Is that right or possibly 4mm?
    Eye with thimble. They do slip over time. Whippings are probably the best way for rope length savings.
    -Will
  5. seasquirt
    Likes: 191, Points: 43, Legacy Rep: 10
    seasquirt Senior Member
    I second whipping. And for longer lasting and tighter, do a second longer whipping over the top, as a double clamp, and sun protection, and abrasion resistance to the first whipping. If a tight loop, roughly sew the rope end in place, before whipping, unless you're an octopus.
    Will Gilmore likes this.
  6. skaraborgcraft
    Likes: 278, Points: 63
    skaraborgcraft Senior Member
    What is the purpose of the eye, how much strain? Saving length is only possible in some circumstances where perhaps a long tail splice would be best if you require the best breaking strain. I use a lot of whipped eyes, but not on anything that is carrying a critical load.
  7. montero
    4m/4cm jute rope attached to the ceiling with straps. It creates a loose arch, serves as a swing for children. I made two figure-eight knots on each end and secured ends with jumbo zip ties .
    Not very elegantly...
  8. skaraborgcraft
    I would say children are a critical load.......but a light one, you could get away with whipping when done right.
  9. montero
    I will do splicing for a better look .
    I need to buy or make splicing tools for more boat-specific applications.
  10. Will Gilmore
    Is the piece of rope you are working with braided instead of twisted strand?
    If it is twisted strand, no tool are needed.
    -Will
    gonzo, montero and skaraborgcraft like this.
