Note: This feature may not be available in some browsers.
What do think of Chris Morejohn junkrig? To me it looks like the ideal modern junk.
The dipping lug is my favorite, are there any chinese versions of such?
What size were the wood battens that kept breaking? How long?
A sharpie's 'chinese lug' should not have a yard, but a headboard instead, giving a strongly fanned leech and a lot less cloth and weight at the head, and very light cloth and 4-5 mostly parallel battens. Light, light, light and it will work fine. Sharpies are light displacement with easy lines and don't need the brute force that something like BERTIE does.
Given a tall unstayed mast, say bird's mouth built spruce or whatever, but as light and stiff and chafe resistant as possible. Sharpie's moderate resistance to heeling doesn't strain the rig because she gives to the gusts. You do need some sort of backstay for going downwind when the boat won't heel and relieve herself. I broke a CR mast off at the deck in a boat many years ago doing just this. It was a real rush at the time and quite a surprise.
With CR chafe is always an issue, the mast chafing the sail and the battens chafing the mast. Modern approaches work with varying success but a carbon fiber mast with a urethane finish is very smooth and would work well. Glued wood has various problems mostly regarding finish and keeping moisture out, but modern finishes properly applied can give a very good result.
BERTIE is the exact opposite type of boat from a sharpie with her large displacement and immense stability/stiffness and as a result has a stayed, grown-stick mast.
This allows me to go with a cooked-in vaseline finish that is very long lasting, incredibly cheap and easy to renew, totally water-repellent down in the checks where it matters and other nice things but this is a grown mast with no glue joints to worry about.
Intensely research what others have successfully done, and also what designs have failed and why. Usually something that has been around for at least 100 years works well, and sharpies are certainly older than that.
Check out the book GOOD LITTLE SHIP by Vincent Gilpin for a good sharpie design read.
The basic idea is go to the woods, cut down a tree, whittle away at it where appropriate, then stick it in the boat. I don't know if your boat is an open day sailor or a 300 ton schooner, but the process is the same.I too have a boat with grown sticks that are going to need replacing later this season. As this is my first attempt at replacing the masts I was wondering if you could give (or point me to) any more info on the masts you mentioned? Thanks BAATAN! (in advance).
Bataan,This allows me to go with a cooked-in vaseline finish that is very long lasting, incredibly cheap and easy to renew, totally water-repellent down in the checks where it matters and other nice things but this is a grown mast with no glue joints to worry about.
Bataan,
Would you mind commenting on your Vaseline finish? How is it made, and when is it appropriate, or not appropriate, to use?
