Jordan Series Drogue Alternative
Discussion in 'Projects & Proposals' started by goodwilltoall, Dec 15, 2010.
  1. goodwilltoall
    Likes: 26, Points: 28, Legacy Rep: 31
    goodwilltoall Senior Member
    Could using black plastic funnels tied to a rope create the same effect as the JSD?
    Peace.
  2. CatBuilder
    CatBuilder Previous Member
    Sure could... so long as you could get the funnels to stay in once piece.
  3. rwatson
    Likes: 495, Points: 83, Legacy Rep: 1749
    rwatson Senior Member
    make 'em red funnels. Much more festive, and easier to see where the line is :)
  4. WickedGood
    WickedGood Guest
    Great Idea!
    And when your not Drougeing you can wear them like a Hat!
  5. TeddyDiver
    Likes: 138, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    Why :confused: what's the point :confused: and you must have an ark to store all those funnels :p:p:p
  6. marshmat
    marshmat Senior Member
    CatBuilder's right- it could work, but you'll have a devil of a time keeping it intact.
    The loads on a series drogue are enormous- several tons of force for the whole thing. The individual cones are not nearly as highly loaded as a parachute or a single-part drogue, but they'd still be prone to damage if they were much weaker than those of the JSD.
    Don't forget the retrieval issue- which is, apparently, enough of a pain with the real JSD where the cones can squish flat to go around a winch drum.
