Jet power on warped bottom hull?
Discussion in 'Hydrodynamics and Aerodynamics' started by nbehlman, Oct 18, 2011.
Thread Status:
Not open for further replies.
  1. nbehlman
    Likes: 3, Points: 8, Legacy Rep: 50
    nbehlman Junior Member
    I am planning to build a 14 foot runabout in the style of the early 30's and 40's chris crafts. The power plant is a 70hp TigerShark jet ski motor and pump. I am designing the hull from scratch and I wanted to see what the experts on this forum have to say. If you have any comments or advice on what types of design features I should incorporate into my hull, please share them! Here is some basic info:
    http://nbehlman.com/hullprofile.png
    length: 14ft
    beam: 4.8ft
    weight: 650lb (jet ski weighs 476lb)
    deadrise: 6.5 deg
    draft: 6.5 inches (one person aboard)
    Are there any special considerations I should take into account when designing a hull for a jet drive? These hulls are meant to take an inboard prop. I have noticed that jet skis have a much more rounded hull, while my boat will have sharper chines and a low deadrise vee bottom.
    I have looked around on the internet for similar projects and there seem to be quite a few. Most of them are simple "what happens if I do this?" type projects. I came across one site that shows a very strange profile below the waterline:
    http://www.sponbergyachtdesign.com/Designs/IC20 Profile single small.jpg
    It looks to me like it would create massive amounts of pressure drag because of the keel line near the intake.
    I found a video of a chris craft converted to a jet drive:
    http://www.youtube.com/watch?v=uBUUeNfGjTg
    At the 10 second mark, you see it go into a drift turn characteristic of jet boats. I am concerned that these kinds of turns could cause the hull to "trip" over the nearly square chines.
    I expect that my hull will provide a great deal more lift than the jet ski hull, but will of course weigh more. I have done quite a bit of work with the Savitzky power prediction method, but I suspect it is not very accurate for jet boats since the kind of suction onto the water. My target speed is 30 mph. The jet ski currently does 40 mph.
  2. Boat Design Net Moderator
    Likes: 192, Points: 43, Legacy Rep: 1004
  1. Matti Nakkalajarvi
  2. SET Project
  3. jjj
  4. Maverikk
  5. radityonugra
  6. IDoSeaDoo
  7. Phancy
  8. Phancy
  9. Fergenstine 1
  10. richard gray
Thread Status:
