Jet impeller speed vs water flow
Matti Nakkalajarvi
New Member
Joined
Apr 12, 2024
Messages
2
Reaction score
Location
finland
I'm about to make a new boat. I've had good experiences from yamaha vx110 engine and pump combo on the boat i have now.
I was thinking of a bigger yamaha pump from a more recent model than the vx. Also was thinking about suzuki's 1.6 gas engine and put a turbo in it, and about 200hp/ 6000rpm. Buddy of mine has one in a car and it works.
Now to the question: Is water flow about linear in a jetski pump compared to rpm?
Yamaha pump pumps at 8000rpm at wot and the engine i'm thinking is good for 6000rpm to be on the safe side.
What do you think? Crappy idea all together, or the best idea yet?
For a jet with constant nozzle size, the flow is proportional to rpms; the resulting pressure is proportional to rpm^2 and the required power is proportional to rpm^3. Remember that the pump power is flow (m3/second) times pressure (N/m^2); all provided there is no cavitation!
This also means that at a given forward speed, the thrust is proportional to rpm^2, as long as there is no cavitation. So, if the pump absorbs 200 hp @ 8000 rpm, it can only transmit 200*(6000/8000)^3 = 84 hp @ 6000 rpm with the same impeller setup.
Thanks for the reply. I was thinking that it couldn't be linear based on my *** experience.
Back
