Good morning, I will be beginning another build this winter. I plan to build a bateau GV11. I will be grafting in a yamaha 650cc jet pump and engine after completing hull to plan specs. Plans call for 1/4" ply for bottom/sides and 3/8 ply for transom and support frames/seats. I would like to overbuild the hull in order to give some reserve safety for the high likely hood of rock or submerged log impact at high speed in shallow water. Here are the options I have. 1. Build with 3/8 ply supports and transom. 1/4" bottom and sides then Sheeth with 6 ounce fiberglass then a layer of xynol for impact and abrasion resistance. ( this is what i did when building my spira "Endurance" boat build)
2. Build with all 3/8 ply and a layer of 6 or 9 ounce fiberglass cloth.
3. Build with 1/4" sides 3/8" transom and supports. And sheeth with 1200 or 1208 or 1700 or 1708.
I will be using marine grade baltic birch found locally. 1/4 is $70 per sheet and 3/8 is $80.
I expect to be moving at around 40mph with the boat weight around 200- 250lbs and the 50ish hp jet engine. The original plan would go 25mph with a 10hp outboard and two passengers when build to 110lbs. I want this boat to be stout and safe.
I would appreciate you guys opinions and any concerns.
