Jellyfish swarm cripples Norwegian ferry's engines
Discussion in 'Boat Design' started by Squidly-Diddly, Oct 10, 2011.
  1. Squidly-Diddly
    Likes: 134, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
  2. michael pierzga
    michael pierzga Senior Member
    Ya..jellyfish rafts. Every now and again I face jelly problems. Normally only affects you if the boat is stationary....the generator cooling system suffers
  3. Frosty
    Frosty Previous Member
    Its jelly fish season here it would seem. Not the box jelly,-- but they are around and have killed tourists but the longtailed ones that sting.
    Man I got a sting off one one day and I could not believe the pain as I looked at my ankle to see ---nothing yet the pain was excruciating,.
    I tried Bleach, petrol , deisel, urine , lemon, vinagar and finally the pain started to fade probably not becaue of the chemicals I used but because of the time factor.
    You need like I do have a strainer system thay you can rod out without taking water. A simple stand puipe taking the filter above your water line for easy spill free maintenance, and of course no bends in the bit to the sea so it can be rodded.
    If you go to sea you just got to have these things.
  4. michael pierzga
    Ive had big jellies wedge their head into the thru hull opening and block water flow.
  5. Frosty
    Ive had fish swimming in the perspex strainer many times. I feel sorry when I hit the start but ---I get over it.
  6. sabahcat
    Likes: 28, Points: 0, Legacy Rep: 273
    sabahcat Senior Member
  7. Fanie
    Fanie Fanie
    Doesn't heat neutralize the poison, Frosty ? Swearing helps a lot too, you just have to use the right words. Not oly does it get the jellyfish to make a hasty retreat, the people leave too :D
    Since when does a tough old sailor like you bawl about 'excruciating pain' ? Sounds more like something you expect from a teenager... unless you're in tha stage of old age now... ?
  8. Frosty
    Ha --tough words from he whom hath not been stung by a jelly fish.
    What bit about excrutiating did you not get?
    Im telling you ,--you look down expecting to see your foot ripped off.
    Im a tough guy --I laugh in the face of the dentist.
  9. Fanie
    Fanie Fanie
    Jellyfish dies instantly when they come in contact with me.
  10. FAST FRED
    FAST FRED Senior Member
    Keel cooling solves the problem.
  11. Frosty
    Yes is does if you like going slow.
  12. Squidly-Diddly
    I bet no one was volunteering to show off and jump into that swarm
    of Jellies and be the hero that saves the ship, no matter how many gorgeous blonde Scandinavian girls were watching.
  13. Frosty
    Whats that smell--is it the pile of dead squids or the Scandinavian girls.
  14. FAST FRED
    "Yes is does if you like going slow."
    One version of keel cooling is to simply use the hull portion in contact with the water as the cooling surface. ZERO loss of speed , and cheaper than purchasing an outside keel cooler on a metal boat.
  15. michael pierzga
    " skin" cooling works great for refrigeration, AC. its these two units which get clogged with jellies or plastic when at anchor .
