sdowney717
Senior Member
- Joined
- Nov 13, 2010
- Posts
- 1,600
- Reaction score
- 118
- Location
- Newport News VA
http://phys.org/news/2013-07-boat-owners-barnacles-eco-friendly-method.html#nRlv
Ivermectin you can buy for use as a bug wormer for animals. It is easy to buy.
All you need is a small amount put into the paint. Notice only 0.1 % per liter.
You can buy it in paste form at 1.5% etc...., So for a few dollars you get an safe effective bottom paint.
here is a paste of 1.87%, also can get it in liquid form.
https://www.smartpakequine.com/dura...e8ilnY8cezXYl-hI6pqMfM_ZEJdbKpSJSHhKj7TvD_BwE
Just calculate the dose to 1 gram per liter.
Now what paint can be used versus buiying a cheap bottom paint and adding Ivermectin?
Ivermectin large amount pour bottle.
http://www.revivalanimal.com/Ivomec...L0Gs-IC0HHzSfUcRyaykovDDokeyXJxYCY9A2v9vD_BwE
http://www.ebay.com/itm/Durvet-Iver...672?pt=LH_DefaultDomain_0&hash=item565bdd13f0
I think to get sufficient amount of Ivermectin into the paint using these sources as a DIY idea, you would have to use a larger bottle and mix it into a latex type of paint.
Perhaps the 1000 ml size which is $50 would give you a 5 gram total amount of Ivermectin which is enough for a little over a gallon of bottom paint.
If you can get this in a higher concentration would be more practical.
A good effect has been achieved with only one gram of ivermectin per litre of paint, or a concentration of only .1 per cent. The effect lasts for many years and can replace the copper currently used in hull paints. The research indicates that only very small amounts of the substance leach into the water.
