Hi all
I'm designing the electrical system for a new boat, and I have a question on wiring (again - there are few I see, although I can't find this one in the archives)
Specifically, regarding minimum size for wiring the USCG code has the following exception
This section does not apply to communications systems; electronic navigation equipment; electronic circuits having a current flow of less than one ampere; conductors which are totally inside an equipment housing; resistance conductors that control circuit amperage; high voltage secondary conductors and terminations that are in ignition systems; pigtails of less than seven inches of exposed length and cranking motor conductors.
but I can't find a similar exception for ISO-10133, the rest-of-world equivalent. Anyone know if there is one, and can they point me to it? If not then even an NMEA-0183 to USB connector or a VGA cable would have to be wired with 0.75mm2 strands....
