In addition, I shall also say that there is a "twist" for shear stress calculation in the annex H. If you take a look at the way this shear stress is computed, you will notice that, in order to get a value as close as possible to the maximum shear stress, at ZNA, you have to split in two the ply by which passes this neutral axis.
To illustrate this, please take a look at this example. Panel composition is [QX900,CORE10mm,QX600], from the outside of the hull to the inside. We are interested in finding the maximum stress, occuring at fixations. At these locations, we expect to find the inside of the laminate in compression, and the outside of the laminate in tension, as shown in the picture below.
The studied laminate is not symetrical, which means that the neutral axis (NA) won't be in the middle of the laminate, but will be slightly offset outwards. This fact won't change the outcome of this demonstration, as one will understand in the end.
The shear stress (due to flexion only) is calculated, in the table H.2, at the plies interfaces. With the given composition, the neutral axis will be in the core, which means that one part of the core will be in tension, while the other part will be in compression. As demonstrated in mechanics, the maximum shear stress will occur exactly at this position, ie at the neutral axis. To get this value, using the calculation method of the table H.2, you have to split the core, in order to have a ply interface at the exact position of this neutral axis. In the picture below, each computed ply is represented by a cell. ZNA stands for "the altitude of the neutral axis" and Zcalc stands for "the altitude where the shear stress is calculated for the core".
To illustrate the effect of splitting the core in two parts, one below the neutral axis, and another above, please take a look at the following calculations. First, the calculation done with a single ply for the core. You can see that the value for ZNA is 4.99 ( col 14 ), that the core is computed as if it was entirely in compression (col 23). The value of the resulting maximum shear stress is given in (col 28), and is equal to 0.28MPa.
Then, let us see the same method of calculation, applied with a split core. The value of the ZNA stays the same. But now, as you can see in (col 23), the inner core ply is now in compression, while the outer in now in tension. Which is physically correct.
The value of the resulting maximum shear stress is increased (col 28), in comparison with the first calculation, and is now equal to 0.2988 MPa, more than 6% higher than the one computated earlier.
In this example, the difference between the two approaches could be negligible, because it does not change much the computed compliance factor (col 29). But when you work with laminates with very thick cores, this difference could be important, to a point where you cannot neglect it anymore. Especially if you're working on racing boats, with very optimized compositions. In practice, I recommend to take this fact into account, and always split the ply by which passes the neutral axis. That way, your calculations will be correct, and you will always be sure to compute the maximum shear stress value from this "H.2" method.
To do this,
(1) make an arbitrary split of the ply you estimate that will be at the neutral axis, in two equal parts (for instance).
(2) Check that the neutral axis passes indeed into one of the two parts (col 14, 3.05 < ZNA = 4.99 < 8.05). Note the value.
(3) Adjust the outer split in (col 12) such as the sum of thicknesses from the outer ply to the outer split (here col 12: 1.100+3.890) is equal to the ZNA (col 14, ZNA = 4.99 = 1.100+3.890)
(4) Adjust the inner split in (col 12) to get the desire thicknesses sum of the two split.
(5) Verify that the ZNA value (col 14) has not change, with respect to the value noted in 2.
(6) Like the post if you wish. Cheers,
