ISO 11812: Question about sill height
Discussion in 'Class Societies' started by Cees, Jul 9, 2010.
  1. Cees
    Cees New Member
    ISO 11812 requires a top of sill height of 200mm for design category A.
    To me it is not clear from these rules whether it is allowed to acquire a sill height of 200 mm with help of the fixed profile of a hinged/sliding doorsystem, which has been attached watertight to the steel sill of the hull. See also attached figure "sill height.gif" to clarify this.
    The question is now: Is Situation 2 allowed?
    Your help is highly appreciated.
  2. TeddyDiver
    TeddyDiver Gollywobbler
    "The sill height is the lowest height of the openings considered to be sills."
    So yes, 2 is allowed..
  3. apex1
    apex1 Guest
    Yes it is.
  4. dqb18
    dqb18 New Member
    2 is acceptable.
  5. Lister
    Lister Previous Member
    This is the definition of "sill"
    Yes it is confusing. I suppose 2 is OK, but someone can find it wrong, since the sill as to be under the door.
    Anyway play safe.
    Lister
  6. Ike
    Likes: 430, Points: 83, Legacy Rep: 1669
    Ike Senior Member
    I used to be on ABYC's cockpit and scuppers committee, and from my understanding of it #2 is the correct way to do it.
  7. Lister
    Thank you Ike, it clear this confusion. I was at time in the same confusion as Cees, and you very insight input clarifies this.
    Lister
