is tree sap on older gel-coat a big problem?
Discussion in 'Fiberglass and Composite Boat Building' started by Squidly-Diddly, Dec 20, 2009.
  1. Squidly-Diddly
    Likes: 133, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
    would a good coating of sap on this boat devalue it any more than an afternoon's worth of elbow grease?
    How to clean a couple years of sap off the gel-coat without damage?
    sap will brittle after a while.
  2. apex1
    apex1 Guest
    Hot water, low pressure. Kärcher!
    The more solid parts: rug with turpentine, soon rinse with soap water.
    Regards
    Richard
  3. Squidly-Diddly
    apex....."Kärcher" ???
    what does "Karcher" mean?
  4. PAR
    Use a heavy duty cleaner, like "Spray 9" or other. Mineral spirits or turps might spank it, though gasoline will probably wipe it right off. Of course get the area rinsed quickly after.
  5. apex1
    apex1 Guest
    S -D
    Kärcher is the manufacturer of the most common pressurized, hot water units known on earth.
  6. Fanie
    Fanie Fanie
    Good idea Richard, but I was thinking why not just sail it off... Prolonged exposure to water may well dissolve it.
  7. apex1
    apex1 Guest
    At the end, water will dissolve everything, you are right Fanie.
    And Paul:
    I did not say any sort of solvents and agents! Plain, real Turpentine, was my recommendation.
  8. Fanie
    Fanie Fanie
    Oh dear Squidly, there goes your gell coat too :D
  9. hoytedow
    Karcher is great but don't let nozzle get too close to finish or it will cut like a knife.
  10. apex1
    apex1 Guest
    Hoyte :(
    LOW
    pressure was recommended L O W
    imagine a setting you would use to buff up the cherry on the cream on the birthday cake. or so...........
  11. hoytedow
    Yes, I know but it can't be said too often.
  12. somalley
    somalley New Member
    maas aero
    Do you still have this for sale?
  13. gonzo
    Turpentine dries slowly and is works well. There is a general adhesive remover by 3M that also works well
  14. tunnels
    tunnels Previous Member
    A :D blast with a co2 fire exstigisher and freeze it it will just about fall off !!:p
  15. pjssailor
    pjssailor Junior Member
    I have found achohol is the only thing that cuts our pine sap. Try it.
