Is this still considered an RIB?
Discussion in 'Boat Design' started by kach22i, Oct 2, 2007.
  1. Squidly-Diddly
    Likes: 133, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
    another 'semi-RIB' with inflatable OR foam collar
    http://espritnautics.com/?gclid=CNC-mO7Xjo8CFSISQQodxyvtGg
    hit 'product brochure' for all their models
    They seem to be aiming for the super-lux yacht-tender market.
    I've wondered about a retro-fit inflatable collar that could be attached to just about any existing craft, from 10' aluminum fishing boats to ballasted keel boats.
    Aside from adding a big dose of seaworthiness to your existing setup for certain conditions(for small craft) one application for an emergency inflatable collar around a keel boat might be that it would make more sense to 'stay with the boat' if you could keep it from sinking.
  2. kach22i
    Likes: 111, Points: 63, Legacy Rep: 1222
    kach22i Architect
    Why aren't all boats "unsinkable"?
    Would be easy to do, right?
    Cost?
  3. oldcroc
    oldcroc Junior Member
    Hi guy's new here, just an old dive instructor, came across a bombard or zodiac 15 footer in the Grand Camores as a dive boat nothing un-toward here but they had glassed the whole thing, IE all the tubes when asked why, they said that with such major temp changes during the day that the tubes kept leaking with the air expansion, more likely they could not get puncher kits out there anyway I dived off of it a few times worked a charm, though a bit ugly to get back into.
  4. kach22i
    kach22i Architect
    Do you know of anyone who has filled the tubes with foam like some people have done with pontoon boat sponsons?
    Is there a "soft" or "spongy" foam you could do this with?
  5. Omeron
    Likes: 2, Points: 0, Legacy Rep: 31
    Omeron Senior Member
    Its not a RIB, its IRB (inflatable, rubbing strake, boat)!
  6. wet-foot
    wet-foot Senior Member
    kach22i here's one of many that offer foam-e's!!!!!!!
    http://www.wing.com In most situations straight air fill is better.
  7. kach22i
    kach22i Architect
    I know of this company because of the Polyurethane they use is very similar to what commercial hovercraft use for their skirts. Looks like they have some new products such as the Cargo Cat.
    I think the wing inflatables are filled with air not foam, but this one picture really confuses me because I see lots of strange little foam pieces.
    http://www.wing.com/construction.htm
    Omeron, that term is new to me. However one company with a patent uses a sponge rubber foam filled collar that has an inner air bladder for a RIB-like rubbing strake. I think it's intended for Tub Boats and rescue craft which come along side other and often larger craft.
  8. wet-foot
    wing does the foam inner air bladder too!
    http://www.wing.com/product_pages/seaark.htm
    An all air system running a pressure sensitive blower would be more cost effective and make for a far cleaner set-up. just my opinion. When these foam filled systems get old they are tough to repair and can't be deflated like a regular tube can.
