Is this a new power source for electric propulsion
I ran across this site and it appears that it might be able to supply a motor/power source for the many lightweight electric drive threads that appear on this forum
Press – Core Outdoor Power http://coreoutdoorpower.com/press/
Thank you for the link. This motor looks perfect for testing my new drive design.
OCB
No retail information on that Core Outdoor Power site that would help experimenters. OCB, can we see some details of your drive in the electric propulsion sub-forum? Also you might want to find Jeremy Harris's double U-joint electric outboard somewhere on this forum.
Hey Allen,
I got this information off the PDF file Core sent me. I will share my design on the electric sub-forum . I have seen Jeremy Harris's double U joint lower unit. I have tested U-joint oscillation @ 45 degrees. Not sure if constant velocity is needed low power?
OCB
Power Cell: 36 Volt high energy Li-Ion Head speed: 7,000 RPM Boost mode 6,000 RPM Head type: Dual line bump feed Trimmer line: .095" Dia. 20' on spool Chargers: 45 Minute Standard Charger Charger input: 100 ~ 240 V AC 60/50 Hz Charger output: 42 V DC Replacement Power Cell: CEC6600 Replacement chargers: CESC8000 Weight: (with Power Cell) 11 Lbs Weight: (without Power Cell) 8 Lbs
Weight: (with Power Cell) 11 Lbs Weight: (without Power Cell) 8 Lbs Need Assistance?
So basically a 3 pound 36 volt battery.
Could move a rc model quite well, but a pasanger could probably leap back to the dock for replacement cell
I will use this motor for 5.5' ASV
OCB
