Is this a Catamaran or a Quasi-Catamaran?
Discussion in 'Boat Design' started by SmallLight, Aug 24, 2025.
  1. SmallLight
    Likes: 9, Points: 3
    SmallLight Junior Member
    Hello,
    I came across this boat, the “Catfish”, which is described as a catamaran.
    My intuition is that the design will have good initial stability, but is really more of a monohull.
    Is this a good design, or neither fish nor fowl?
  2. baeckmo
    Likes: 890, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    .....a monohull barge. A catamaran has a tunnel with an open water surface between its two hulls, and that makes a difference in behaviour.
    BMcF likes this.
  3. SmallLight
    Likes: 9, Points: 3
    Thank you.
    What are the tradeoffs of this sort of hull versus a Jon boat with the same dimensions?
  4. clmanges
    Likes: 161, Points: 43, Legacy Rep: 32
    clmanges Senior Member
    Fixed it for ya. Text options lack strikethrough.
    My impression is that some tinsmith was trying to emulate a RIB hull and quit before he finished the ends. And what's with the stitch-welds? I assume those are supposed to be reinforcement plates, but I think they're an invitation to disaster; any stress between the two pieces is going to focus on the ends of those stitches and try to unstitch them.
  5. SmallLight
    Likes: 9, Points: 3
    Thank you for the delightful correction!
    I agree - the design seems to reflect intuition rather than careful analysis. When someone thinks they have solved a hull problem with a simple-to-produce, ‘proprietary’ solution, they probably haven’t.
  6. kapnD
    Likes: 558, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    If pushed fast enough, it will function as a catamaran, but only practical in really smooth water.
    It’s basically an overcomplicated Jonboat.
    clmanges likes this.
  7. Ike
    Likes: 511, Points: 113, Legacy Rep: 1669
    Ike Senior Member
    There is a simple solution to your question. The definition of a monohull is simply, sitting at rest in the water with a normal load (people,gear, engines, etc), it makes only one footprint . If you draw a waterline around the boat, and it's just one continuous water line, it's monohull. If you have two separate footprints it's a multihull.
    I doubt very much this boat would make two footrpints even on a plane.
    BMcF likes this.
