On small sailing dinghies like the one I recently built, after the mainsheet passes into the last block and into the hand, all the rest of the sheet just sits there on the floor, getting in the way, sometimes getting tangled, sometimes getting under the shoes, when capsizing it goes over the rail and needs to be hauled back in, etc. There's like 8 meters of slack sheet to deal with when the sail is fully sheeted in. I have a bag for it, and try to put the slack into it when able, but if changing courses often and the sail needs to be let out and then back in again, the sheet is again out of the bag, and I found this solution generally not worth the effort.
I was wondering, has anyone seen or had a low-tech solution to automatically collect the slack end of the sheet in a neat way so that it doesn't tangle and get in the way? I am envisioning some kind of a drum on a low-power spring that could be tuned to be easily overpowered by even a low wind when bearing away, but just strong enough to slowly reel the sheet in when nothing is pulling on it. However I've never seen anything like it, even on racing dinghies, so perhaps there is a reason why it wouldn't work or would just be impractical. I suspect it would require very close tolerance and low friction components to work, which is not low-tech at all.
Are there any other solutions that could deal with this nuisance, apart from dedicated set of hands?
