The age old rule of plate 1" above is a rule of thumb for bog standard boring boats
Another rule of thumb is for every 6" of rear offset, you can go up 1/2" so in theory 1.5" up in this scenario, but all boats are individual and there is no exact science. I am with ondarv. Plate doesn't need to touch water, but some people say it needs to be splashed with water
Highly unlikely you are going to run surface piercing, so with what ever prop you have, does it plane, does it feel stable, does it not over heat, does it corner. If all are ok, you may not be too high, if it gets hot, lower it. If it won't plane, lower it. If your WOT is too low, get a smaller prop If it's too high get a bigger one. Add a blade and you will loose some rpm. Switch to stainless from Ali and you will gain a tiny bit of rpm It's an absolute black art, friends with props are best friends
