is mercury the same as yamaha?
Discussion in 'Outboards' started by mr curious, Jul 26, 2008.
  1. mr curious
    mr curious gunkholer supreme
    just to confirm a rumor that is going around, that some mercury outboards are in fact yamaha outboards with a mercury brand name on them.
    :confused:
  2. Landlubber
    Landlubber Senior Member
    Tohatsu certainly.
  3. mr curious
    yes, my 6hp mercury is the same as the tohatsu
    makes me wounder if mercury makes anything themselves.. :D
  4. Landlubber
    why bother when you can rebadge........isn't this greedy little world out to make the most profit from a sale and get away with it......no one gives a f..k about quality and the joy of actually creating something like our fathers did before us... today it is do it as cheap as possible and make as much profit from it as possible, and certainly make sure it doesn't last...accountants hate things that last, so much for their planned obsolescence.....
  5. Syed
    Likes: 0, Points: 6, Legacy Rep: 8
    Syed Member
    They must be busy in making easy money.:)
  6. TeddyDiver
    TeddyDiver Gollywobbler
    Depends where.. In here Mercury and Mariner are twin brands like Evinrude & Johnson. And about every 5hp 4stroke outboard in the world (except Honda) are from one factory in China. In addition they are labeled with different hp ratings somewhere (maybe 6) so hence the similarity...
  7. powerabout
    Likes: 63, Points: 48, Legacy Rep: 719
    powerabout Senior Member
    Some are some aren't
  8. mr curious
    which ones are?
  9. powerabout
    Merc have been using both Tohatsu and Yamaha for 20 years doing various engines.
    Generally little ones.
    You can usually tell when looking at the powerhead, some look Japanese and some look sensible
    Whats new... MerCrusier also made the Lotus 32valve V8 in the Corvette
    If you have the production capacity some one will use it
  10. thudpucker
    thudpucker Senior Member
    I think my 25 Hp Mariner is a Yamaha. It's a 1997 25M.
    It does not say anything on the castings about where its made.
  11. Ari
    Likes: 15, Points: 0, Legacy Rep: 94
    Ari Patience s/o Genius
    Mercury - Yamaha
    In Malaysia, Mariner below 70 horses are built by Yamaha, anything above that are built by Mercury. But you can still get Mercury built with Mercury name tag for the big capacity engine, the same with Yamaha.
  12. BHOFM
    Likes: 14, Points: 0, Legacy Rep: 247
    BHOFM Senior Member
    Off topic, but the engine in my 2002 Mercury Sable is
    by Yamaha!
    3.9 LITER V8 TURBOCHARGED 372 HP
  13. CDK
    CDK retired engineer
    Most manufacturers list their models with hp, weight and engine volume, so it is quite easy to see which engines are identical. Nowadays everything under 25 hp labeled Mercury or Mariner comes from Tohatsu. Under the OEM brand they are cheaper. Nice little engines that live long and require little maintenance, far better than the engines Mercury made. They should buy a better paint though: if you spill fuel on the cover (with integral tanks you can't avoid that), the black paint peels off like a lizard skin.
    The original gray Tohatsu paint doesn't have that problem.
  14. Landlubber
    One little tip here, the 2 and the 3.5 are exactly the same, there is a restrictive washer behind the carby. Taken out, the 3.5 will make a tinny plane quite well with one 75kg driver.
  15. Pikemann
    Pikemann New Member
    2000 Merc Outboard 25hp
    So is this 2000 25ELH I have a Yamaha or Tohatsu? I need to replace the powerhead and pistons. I just wan to get the correct parts and best deal.
    thanks
