Is Epoxy compatible with Glycol?
Discussion in 'Wooden Boat Building and Restoration' started by tatoski, Jan 26, 2009.
  1. tatoski
    tatoski Junior Member
    Hi, I am planning to build a wharram Tiki 21 here in the Philippines. I've read that monoethylene glycol is a good preservative against rot. Would epoxy still adhere well to monoethylene glycol treated plywood? I need to apply fiberglass cloth/epoxy to the outside of the hull and coat the inside with epoxy. I am thinking about the glycol as an added precaution and added protection together with the epoxy/glass coating. Thanks!
    Tatoski
  2. TeddyDiver
    Likes: 124, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    There's link in some thread (considering the very same subject) around here about the subject I'll check if I find it. But the answer is Yes with precaution..
  3. TeddyDiver
  4. tatoski
    Thank you very much TeddyDiver for leading me to the right connections! I've clicked on the threads and got a wealth of information.
  1. tonyg99
  2. flyingvranch
  3. RMMager
  4. aaronhl
  5. Skookum
  6. abosely
  7. Pete Cross
  8. NoEyeDeer
  9. samhaskins
  10. TorBay
