I'm installing a watermaker in an aluminum sailboat, recently launched. I'd like to mount the HP pump/motor in the engine compartment. The floor in the area is inside of the hull plating. Ideally I'd like a small platform just a couple of inches off the floor that I could bolt the motor to. This platform will need to sit on a couple of sleepers attached on the floor. I'd prefer these be welded to the floor. The boat is currently in the water.
I'm not a welder, so would hire this out. My question is, can a bit of interior welding like this, on the inside of a hull, be done while the boat is in the water, or must it be hauled out to get a decent weld?
Thanks.
Thanks.
